RichardLongley
After help from this forum to get me started, I hoipe you can help again.
When I went to run my new truckat full speed, I found it was stalling. I had read that this was due to the engine running too lean. This was surprising as it was set at 2 and 1/2 turns out.
I turned it out to be richer, and it ran better. After a short time however, as I spun it, the revs picked up significantly, and the car was not moving. The gears / clutch were only engaging slightly, even when the revs were put up high.
Maybe significantly - when I went to stall the engine, by putting my finger over the exhaust, it carried on running. I had to put a kink in the fuel feed to stall it,,,,,,,,
what have I done???
what have I done???
