More help needed with Nitro 18ss
RichardLongley
RCNT Member
After help from this forum to get me started, I hoipe you can help again.
When I went to run my new truckat full speed, I found it was stalling. I had read that this was due to the engine running too lean. This was surprising as it was set at 2 and 1/2 turns out.
I turned it out to be richer, and it ran better. After a short time however, as I spun it, the revs picked up significantly, and the car was not moving. The gears / clutch were only engaging slightly, even when the revs were put up high.
Maybe significantly - when I went to stall the engine, by putting my finger over the exhaust, it carried on running. I had to put a kink in the fuel feed to stall it,,,,,,,,
what have I done???
charliejp
Hardcore RCNT User
Edmond, OK
Bashing
Sounds like your either running way lean or you have air leaks. Check your exhaust coupling and see if you broke it. As for your clutch, you'll need to pull your engine and check it out. I did'nt like the factory clutch so I used one from a rtr MT2 and it works great. Do you have any idea what the temps are getting to?
RichardLongley
RCNT Member
no idea what the temps are.
It was running ok, before somehing changed,, and air getting in made me think maybe that is why the exhaust being sealed didnt stall it,,,,,, air must be getting out somewhere for it to carry on running - I will check the exhaust coupling.
LosiLST
Gone - bye bye.
Washington.
Bashing
Might want to check your manifold. Make sure that where the manifold is screwed into the engine that it is still nice and secure. Also make sure that you have a gasket on there. Check all your fuel lines and make sure there is no cuts or holes any any of the. When you start your engine, is the air bubbles by the carb?
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
R More help needed with Nitro HPI 18SS Electric RC 0
4 UGH!! More help needed... Nitro RC 4
G more engine/carb tuning help needed! Nitro RC 3
D Need help tuning my OS 18 cvr i saw the tuning fourm already but i need a bit more details Nitro RC 3
hamz9561 More Geek Help Computer talk 20
F More help please...servo/transmit Nitro RC 8
hamz9561 Need More Computer Geek Help General Chaos 3
K *Sigh* More idle help! Nitro RC 5
F ok LITTLE MORE help Nitro RC 1
h8z2luze More computer help please. General Chaos 7
ajames942 More Computer Help General Chaos 3
S Need more clutch help please!! HPI Savage 16
M Appreciate help once more ASaP HPI Savage 5
4 Really great lube but cannot find it any more HELP PLEASE!!!!! Nitro RC 8
6 Can I throw my lightning rr threw a window? Starter problems help. And more Buggy and Truggy 23
P ok i need more help with this truck!! HPI Savage 3
D More help for the newb Nitro RC 2
Shockbender98 More t maxx issues Nitro RC 4
RookieNumberss Good brushless motor that gives more speed than velineon 3500? Electric RC 21
drivinggun More Everything ? Nitro RC 2
T Why won't my 2.5 crank for more than a second Engines 4
olds97_lss Few more Hot Racing updates to my Traxxas Stampede 4x4 VXL Electric RC 2
Peeeenuuutt Well that should be broken a lot more then it is Monster Trucks 8
godale03 Mavic Pro, Fly More Combo RC Aircraft 9
H What are some Great Upgrades for the Losi 22s SCT 2wd RTR to be more compedative Short Course Trucks 13
TRXaddict RIPITRC MORE LIKE RIPOFFRC General Chaos 4
badboy2 HPI Savage TVP need more info.. Monster Trucks 2
B Hobbico no more HPI Savage 3
HPIguy $20 Off $100 Or More General Chaos 0
bobthebob Temp gun never measures more than 210F at glow plug HPI Savage 14
S more power Chassis & Drivetrain 7
bobaloohoo Wheelies and more wheelies.. so many powurrss!!! Nitro RC 18
J Nitro or Electric? Which gets you more run time foe the money? Electric RC 41
Rolex Time for more wax General Chaos 1
D need more efficiency Nitro RC 13
S Front has more power than rear? Traxxas T-Maxx 10
Spyke_696 Just ordered my rs4 question on a part that isnt made any more Nitro RC 0
M more snow comming General Chaos 3
P Are nitros more trouble than there worth Nitro RC 12
1 T-maxx is not dead no more lol Traxxas T-Maxx 5
scootr Trx 3.3 want more mid range.. Traxxas T-Maxx 3
Bkyd Basher a couple more sct bodys Paint & Body 5
hsdtech XR8 Picco .21 More Power Than Stock M26 in Aftershock? Nitro RC 0
Bkyd Basher A few more paint jobs done Paint & Body 9
B what would have more torque? Electric RC 2
A Engine turns on but no more throttle response **Strike #2** (Gearbox problems) Nitro RC 4
Bkyd Basher More fuel holding Traxxas T-Maxx 16
A [Noob question] Engine turns on but no more throttle response Nitro RC 24
hulkmaxx More carnage Traxxas T-Maxx 6
Bkyd Basher A couple more so so paint jobs! Paint & Body 5
