Modified udirc snow leopard 1/24
alteredfabrc
Hartly, DE
  1. Crawling
This is close to a final version running a injora fat viper/goup esc had to swap connectors. Also using a dumbo x6 tx. and a lot of stuff was made from scratch and came off the top of the head while not trying to blow the bank on a what might be a complete junk build but it’s turned out to be one of those goes wherever you point you kind of things it was fun testing the possibilities with a non scx24 based chassi. Added a custom one of a kind suck down winch using a spare servo works for front/rear
Yes sir. Started with a non Scx based chassi and converted as many parts as possible lol
How can I say this and not sound rude 🤔
You took away everything that makes that thing great. Out of the box it was never the best but has so much potential. A few tweaks and mods takes it to next level capability. I have a thread on what I did to mine.
Great ingenuity though!
I think there sub par out of box for level of technical and slow crawling I like to see it was going to be very hard to reach the confidence level without breaking stuff every couple uses with only upgraded udirc parts. I've broken scx24 axle shafts, driveshafts, stripped pinions on this setup I don’t think the udirc parts would nearly hold up. It will do an incredible 7” vertical break over and drives up and holds 65 degree uphill climbs. Tried using all the real life buggy advantages I could
