Build Thread Mini STE Build
The problem is that i don't have wide open smooth surfaces to run. Just about all surfaces i run on are uneven so i need something that can soak up the bumps without losing control.
I do have a textbook that i would be willing to trade you for the E-10. you ship first. :)
i spent the 125 i was going to use for an onroad for a bnib losi mini rock crawler............
now i need to get rid of this velineon setup.....
Hyper ste
I'm interested in a hyper ste & I like your set up. Tell me more about your setup & the durability of this beast!
here is how it sits now.
My only problem right now is that the motor still likes to run hot. Its not hot enough to damage the motor but its hotter than i like. The esc is barely warm which tells me that i can gear it for more speed and that should drop my motor temps. The problem is that its almost too fast right now so i'm not sure what i am going to do.
There are two things that the truck needs right from the start.
1. Stiffer springs in the front.
2. CVD's in the rear. (the fronts fit and the stock rear dogbones are soft and prone to bending)
Hey I got your message. I want to learn more about it & see what can be worked out. Email me at [email protected]. I like the new additions to to the truggy. What motor are you running now?
