cbaker65
RCTalk VIP
Those wheel adapters did the trick! Truck is back on proper tires.
So now I've got the 150A speed control in with the big tires and I'm still seeing some cogging, although not as bad as before. Next step will be to drop the pinion gear a few teeth, and if that doesn't do it, I guess I'll just have to live with it because my spur gear can't get any bigger without hitting the chassis.
Second order of business- diff oil. I'm currently running traxxis 50,000 cst oil in my center diff. That seems to be not thick enough because every time I get on the gas in the street, the front end will pick up for a second and then drop back down over and over again. It ends up stuttering down the street.
What weight oil do people run in center diffs of their big heavy trucks to be able to pull wheelies ? Or is there something else I should be doing to set it up?
Electric conversions are a different beast ,I can't help you there ,however ,to me those blue springs are a bit mushy ,I have the copper colored ones!
Your truck is looking suweet!..
