HeartBreak
RCTalk VIP
Okay, I'm about to pull my hair out on this one. I've searched the forum until almost going cross-eyed, and can't find anything to help explain what I'm going through...
I have an MBX5 Prospec buggy with an OS VZ-R II engine in it. Did the break-in, up to the point where I can pull full throttle. This is where the pain begins.
Engine runs perfect for roughly about 10-20 seconds, then it starts to heat up FAST. Hits 270F+ at idle. Yes, IDLE. Needle settings are flush on all, idle air opening is set to allow the motor to run without the clutch engaging. You know, standard fare. This is all sitting on the starter box, wheels off ground, brakes not dragging at all.
Now, here's where the fun begins... A pull on the throttle usually causes the motor to die at around 1/3rd throttle. Leaning it about 1/8th of a turn allows me to get more throttle. Eventually, I can get it to reach full throttle, but that's only with a glow plug lighter attached. Temps approach 310F at this point. Without the glow lighter attached, engine cuts off suddenly.
With the glow lighter attached, the engine stutters, like it's bumping itself over. It also revvs high (sounds like a woodpecker) when returned to idle.
During all of this, lots of blue smoke and spittle from the exhaust.
It has a P7 plug in it, and is being ran on 20% Trinity. I'm also aware that because of the excessive heat, the bearings are probably fubar'd.
Ideas?!
Any help would be appriciated; otherwise this motor is going to meet its maker, in the form of a 10 pound sledgehammer, and mailed back to OS with a rather 'nice' letter.
Ideas?!
