Hey, cool, I bought one of these the week before Christmas.
A few tips. Flying it indoors is TRICKY! One very good reason, "wash".
The swash plate is designed to pop open rather than break, so if the heli suddenly wants to fly off at high speed after take off, you'll need to push the sway plate back together as the servo linkages are way out of whack.
Trying to hover at a few inches, within ground effect (the first height it seems to "settle" at when it lifts off) will be unstable as the down wash from the rotors creates pressure on which the heli floats. Real heli's use this for taxi-ing and call it "hover taxi" because pilots often have creative and original minds
The downside for such a small lightweight heli the wash also creates eddies and vortexes which pull, push, bounce and sway the chopper about.
Try hovering up at 2 feet, it's easier but the throttle gets harder and it's a harder drop if you need to kill the throttle in a panic cause your about to hit something, which brings me to the next point about wash.
There are 2 further effects of the wash on objects other than the ground. Reflections and wall magnet'ing. Objects around the house, like cupboards, chairs, doors, walls, sofa's reflect and otherwise get involved in the wash off the heli causing more eddies and vortexs to buffet and jerk the heli around. The other, more annoying effect is "magnet'ing", I'm not sure of the technical term for it, but basically as the heli gets close to something like a cupboard door in the kitchen, it creates a low pressure area between it and the surface immediately causing the heli to make a B line for the obstacle.
Be careful with spot landing on counters as well. Once you pass the edge, you will proably re-enter ground effect again and the heli become unstable. More unstable than the floor as the ground effect has a edge to screw it up and make it even more turblulent. To see just how turbulent, put something that will make smoke on it, or fire a CO2 fire extinguisher at it while it's hovering. It will create huge spiraling vortexs of smoke/co2 around it.
All of this means that hovering this little blighters indoors is a complicated affair with lots of jerky sharp control inputs, cutting of the throttle to save the blades.
I chipped all my blades hovering indoors and popped the swash plate twice in the first day, until, while trying to spot land on a counter in the kitchen lost orientation, paniced and dropped the heli face first into the counter and 4 foot onto the floor, snapping one blade in half and splitting another all teh way down the blade. 2 sets of new blades : £12.
Outdoors... outdoors it's a completely different little puppy. It's almost boring if you have plenty of space and no wind. It will hover around at 6 foot with the hands off the sticks if correctly trimmed. It will move around a few feet and the tail twitch occasionally but it's relatively tame! You'll find you will use 100% throws on the right hand sticks and wonder why it's not going very fast. Thing is, indoors it was getting close to it's top speed anyway, it just looked too fast!
DONT FLY IN WIND! It has a top speed in any direction of about 3mph. Fly it in 4mph wind and you will be chasing it.
Great for practicing orientation and spot hovering, but nothing on a proper heli.
Real Flight - G4.5 was my next purchase, thinking about a Blade CP or Blade 400, but they are not auto stabilising like the CX3.
Hope this helps.
Paul
