Build Thread Luke66’s Arrma GROMs build thread. (Typhon/Mojave)
Here’s where I was last night:
Many parts from one car, below:
Rebuilding whole car, more coming soon…..
I WAS working at a steady pace…. But then I noticed @Littlemotor ‘s build thread and that went out the window……
Got the lower arms on:
Now working on the hubs…. Cleaning bearings up. One done, three to go:
Stock GROM steering rack is a piece of crap. Fully plan on replacing it with a Aluminum one.
But, I made due with what I had, took it all apart, cleaned everything up, loosened/tightened up where needed. Smoother, but not great.
At this point, I would have put on the upper ‘top deck’ as I call it, to cover all the drivetrain/steering/diffs, but the old one had cracks in it, letting in dirt/othercrap. Therefore this rebuild. Gonna be getting one of them soon. Now, back to building.
Was trying to solder on a new connector…. The lead got hot and moved in the case, when I tried to bend it back, snapped. So, gonna either have to get this thing EC3 connectors or try with some other IC2s. Would have to buy more though. If I went EC3 I’d need new batteries, but getting them would be cheap.
If you have a connector for a battery in IC2 and esc side, connect them together like you would if you were plugging in a battery, and that shouldn't happen again.
