- Arizona
- Racing
- Scale Builder
I've been working on building an ARRMA Typhon GROM BLX into a a speed run car. I am new to RC and haven't done this before, so I'm still learning plenty about how to setup the car and make the runs. My goal is to get as fast as I can with the stock motor and ESC.
I've made a fair amount of changes to the Typhon, but have not pushed it for any high speed runs yet. I have mostly been waiting for some cooler weather (I'm in the desert!), but that waiting has given me time to keep modifying the car to (hopefully) improve it's speed run capabilities.
You can view the history of the build (started 2 weeks ago) at this link https://www.arrmaforum.com/threads/typhon-grom-blx-speed-run-build.79071/
I'll start this thread with explaining the car in it's current state, mainly the mods as of tonight!
- Losi NASCAR chassis/front splitter/rear diffuser
- TLR Aluminum 203.5mm driveshaft
- Extotek steering bellcrank
- HR steering links
- BSR Nitro 30mm foam wheels (38 shore)
- Arrma 31T pinion gear
I need to give it a new shakedown run, which I will likely do again on 2S only and hopefully get its full speed on 2S in this configuration. My last attempt in the Typhon chassis only hit 41mph but I ran out of road so it should have gone a little faster. I expect this to reach at least 70mph on 3S.
If my 3S tests with this setup go well, I am probably going to try out an LRG RC 44T spur gear out which I think could get this up to 100mph if aero and electronics don't kill it.
- HR steering links
