Greywolf74
I'M TO BLAME!
Lifetime Supporter!
RC Showcase: 8
- Thread starter
- #21
IDK, hard to say but I never had either of those issues with my LST2 or my XXL. Sucks you had such a hard time with it.I had the aftershock which was a trimmed down LST1 with a weak 2 speed. I put an LST2 2 speed on it though when I put a LRP28S3 in it. I got to about tank 6 of break in with that engine and the stock two speed locked up.
I was pretty sure the LST1/2 both used the same chassis rails, but I could be mistaken. I went through a lot of them before making my skid plate. The part numbers differed, LOSB2255 vs LOSB2256. Appears the 2256 are listed as fitting the LST2 and Aftershock, so not sure which ones I ran. I'd assume I ran both at some point.
They would break here:
I made these first and they helped:
I wanted something to cover the servos, so I ended up with this:
That small bar on it was steel as my skate park was grinding through the skid I made. So I put a beveled steel bar on it to deal with it as it was easier to make that every year or so vs remaking the entire skid (which was a real pain to get the bends right just using a bench vice).
The two speed would work fine for a short while, then it would hop the flat spot and lock up. I'd replace the hub, shoes and pucks and it would last for a while, then do it again. I did have mine geared taller as I ran smaller/lighter tires on it. Not sure how much that would have affected it. I ran +2 pinions and did the gear flip mod in the trans.
I guess it doesn't matter much really anymore since it's not likely to make a come back.
