Your going to have to set up your throttle like this for a BB application. As 4910 stated that is called a direct push pull setup. Also man I am not knocking the build but as Hotrod said those Integy arms are prob going to give you issue's.
You just use the throttle servo mounts from the original chassis and locate them on the side like mine.
I love this truck.![]()
So update I plugged the servo and throttle servo in the right channels and It I turn it on and the light lit but no movement in either servo I'm using completely new servos there's a link button do they have to be programmed maybe?
