LRP engine in tmaxx 3.3
This is the servo I got also has a bag with bunch of stuff with it no idea for what lol
That will work.
Hitec HS 645MG Specs:
Torque: @ 6.0V:133.3 oz-in
Speed: @ 6.0V:0.20 sec/60°
It seems those to bars going from back to front are just touching the steering linkage making it hard for it to turn I was thinking of grinding the edges a bit to make a clearance what do you think
I would put the skid plate on it first, & bolt it down with all the screws & see if it the rubs.
If it still rubs then I would mark the areas with a sharpie that need sanded & pull the chassis braces off to sand them.
The Servo Savers in the links I post bolt down right to the top of the servos output spline.
So I grinder the edge a bit now it's perfect I went to put the skid plate on and the holes ain't lining up dammit back to the grinder uploadfromtaptalk1403227822484.webp
Gonna have to grind that back just a tad so the skid plate holes line up
That skid is really far off, are the steering posts lining up or are they off too?
The skid should fit without grinding, a small bit of sanding if it's a little bit too tight, but something is off, I have had to do a small amount of sanding
to get some parts to fit well, but that's too far off to be a sand it to fit fitment issue.
Take a few pic's of the front end, top/bottom/ & both sides, for a better look at whats going on.
So that link you posted I add that directly to the servo
Yup, right to the servo output shaft.
OK will do once I get home from work the skid plate is from a 3.3 maybe it has to be a 2.5 plate and yes it does line up on the steering
4910 is right that's way to far off of a fitment issue man. I haven't been able to get on for awhile looks like it's coming along though.
Hey hulkmaxx I thought u forgot about my build lol Ya it's weird how it's off I thought. Maybe because it's the 3.3 skid plate
