Lower link placement on swx
Japko
What do you guys say about this lower front link placement?
I think it improved the handling, but need to get on the rock to try it out...
should work just fine. whats your wheel base at?
Looks good to me too, but I would stretch it as close to 12.5" as possible, but that's just me.
I guess there's many ways to do that...
Which is the best one in this case? Should I try and lengthen rear lower links?
You could run longer rod ends on the axle side, but the ones you are running look pretty long already, you could also just add a spacer between the rod end and the lower link about 2-3MM making it a little longer, or just get longer lower links that would stretch out the wheel base as close as possible to 12.5"
