- San Jose CA
- Racing
- Crawling
I have a TRX-4 (2-speed and lockers) and want to lower the CG.
My current setup is factory frame & links (except drag link). Springs are all the way down.
Front
Over all I'm pretty happy with the weight distribution (it climbs) but the side hill could be better and thinking the CG might help. I could mess with the foams but they aren't slide as much as the truck tips.
Some thoughts.
Front
- Brass diff cover
- Brass C-Hubs
- Brass portal cover
- Brass wheel inserts
- Brass diff cover
- Brass inner portals
Some thoughts.
- Use the center battery tray, it will lower the CG a tiny bit, but that throws the weight distribution off 54/46.
- Lay down the shocks a bit more to lower the chassis
- Remove the springs and run 100% droop.
- Start removing the inner fenders and replace with shock towers.
