Low power drill + Portable soldering iron
New Jersey
this post is a two parter lol looking to expand(replace) the tools I have because I bought cheap and learned the hard way.
so firstly I know how people say becareful drilling into the plastic and stuff I was wondering if anyone has used a low power drill and what their experience is with it, I used a normal cordless just very carefully to build my car. I also was just looking and found this drill on amazon and was wondering anyone had thoughts on that.
next I had seen this portable soldering iron , this seems like a great thing to have on hand when at the track in case something bad happens, but I really only see my self using a soldering iron a hand full of times. how useful would one be to have?
I have two of these... One for work and one for home. Adjustable clutch, two speeds. Comes with two batteries.
Metabo HPT Cordless Screwdriver https://a.co/d/9tgCjHz
For a soldering iron, I'd probably stick with a corded one. If I thought I might need to solder something where there wasn't an outlet close by, I would just drag along my inverter and plug into my (full sized) car.
I have heard a few guys say this is decent, but I have never tried one.
UY CHAN Original TS101 Soldering Iron Station Kit Upgraded from TS100 DC 65W PD 45W Power Programmable Smart Mini Electric Portable Soldering Pen with B2 Solder Tip USB Type C Cable https://a.co/d/fAuelSu
I've got a similar screwdriver, its kinda okish, it wont drill into anything at all, its more for pulling screws, i use mine to tighten down my screws then finish the tightening with an mip screwdriver. to avoid stripping (doubt this can anyways but safe rather than sorry)
if you can check out the walmart tools, the hart screw driver "alledgedly" works great for rc purposes as it doesn't have the power to strips things unless you're trrying to strip it.
i bought the one you linked basically tho same thing differnt name.
i would have rather gotten the drill as it would get used more o0ften.
i see a lot of people use this drill @Snotbottom posted as well, its similar to the hart one i was mentioning, both are way better options
Any cordless screwdriver will work as long as it has a clutch on it. That being said, even at the slowest speed and lowest torque setting, certain types of plastic are still able to be stripped out. You will need to exercise caution when screwing things in to soft plastics.
iFixIt is a known good brand (no personal experience, but they have a reputation as being good tools in the IT world). Only thing I would say is invest in a good station before buying a portable. just my :2cents:
For a budget station with good capabilities, Id recommend THIS
thanks for the tip about the drill I might just stay with what I have for now then, also for soldering I don’t really know if I need to get one when I could just take somewhere to solder quick and cheap for whatever I need
id never drill on a lexon body.Id use a body reamer. as for portable solder iron there are a few butane solder iron from 60 watt to 200watt..I have a few 70 120 and 224 watt ones they all work great.take less than 1 minute to get to set heat.. as for power screw driver I have reconditioned skill and craftmans screw all..with li-ion cells in them.
I use a Skil rechargable driver. SD5619-03 kit. It works well and has 3 different torque settings. Its no precision piece but it has worked well for me in the garage and on my bench. This one has some snot if you need it but not fast.
The new cordless soldering irons look awesome! I hope they are up to the task!
I used to use a Weller butane soldering iron.
It has HOT exhaust out the side so you need to use with caution.
Its not great for tight quarter repairs or board level unless you're super careful but works great for wiring and the exhaust shinks heatshrink quick and easy, same tool.
The Weller was able to get hot and solder decent sized wire in cold temps. It was also able to run cool enough to so|der fine wire without ovetheating. Its a good unit depending on your needs.
This one is newer than mine and looks nicer. Its also a lot more money than mine was too!!! Prolly cheaper outside Weller website. One of mine came from Snap-Off years ago.
https://www.weller-tools.com/sites/default/files/products/images/2024-
09/WEL_T0051606399_IMG-APP_3.jpg
can't go wrong with Weller or Hakko.
That meme is hilarious! 🤣
I have both and can't think of a good reason to try different brands either.
My Hakko station is awseome too!!!
that is interesting, these aren’t immediate need items anyway just things I thought of while putting together something’s I want order
I always like to research and check reviews before I buy stuff.
Generally speaking, its become the part of online hopping that I enjoy most.
A youtube review is ok but when you talk to ppl who use the tools daily for a few years... NOW you have a review worth considering.
