robmob
LET’S GO BRANDON!
Staff member
Losi has a new tire coming out.
Comp Claws 2.2 Tires offer enhanced traction due to their multi-edge tread pattern that will grip in multiple planes on uneven surfaces. The tires also feature a Gription finish, which is like having thousands of micro-lugs over the entire surface of the tire.
The Comp Claws feature an internal sidewall ribbing, which adds stability to the tire for "side hilling" while still allowing the tires to flex and form over the rocks. A stabilizing, external sidewall ring provides also provides consistent "side hilling" traction, even at multiple angles. The tires also feature a 5.2" outside diameter, for increased ground clearance.
Comp Claws will fit on any 2.2 crawler wheel, and come with memory foam inserts.
Features
* Comp Claws offer enhanced traction through a multi-edge tread pattern that grips in multiple planes on uneven surfaces
* A Gription finish offers increased traction over the entire surface of the tire
* Internal sidewall ribbing adds stability for “side hilling”, while allowing the tire to flex and form over the rocks
* A stabilizing, external sidewall ring provides consistent “side hilling” traction at multiple angles
* The 5.2” outside diameter provides increased ground clearance
* Comp Claws will fit on any 2.2 crawler wheel
* Memory foam inserts are included for ultimate performance
http://www.losi.com/Products/Features.aspx?ProdId=LOSA7681B
Features
