Looking for the right antenna wire, any suggestions?
zombie213
That small black wire to the right of "SJ" is what I need to replace but every cable I see has plugs on the ends. I just need a normal antenna wire like that one, but longer
the ones with the plugs are coaxial wires like you home cable but that is much larger.what you want is a gauge sized wire .strand count will matter . not sure this is the right wire you need but 20 ga is .032"
Could you help me find the exact ones I need? Same width but longer
I really can't tell the size from that picture.. de-solder wire and cut it count strands.. and micrometer size... there's international charts online that will give you what size ... you can always use a thicker gauge wire then use the amount of stands that will fit in pre drilled hole. but b4 that you could cut a little more insulation off then finely solder all wire together and slide heat shrink tube over exposed wire( you can even repurpose a piece of wire if you have a old dead piece of electrical thing old pc ..so on)
