Looking for ball or gear diffs.
biggman100
Corning, NY
I am looking for a newer, more current ball or gear diff for a truck i have (Racers Edge Pro2), that i can no longer get any diff parts for. All i am looking for is a used diff that i can see if it will physically fit in either the gear or ball diff transmissions i have for the truck. It doesn't have to be a working diff, as long as it isnt destroyed.
The rear end seems to look a lot like various Traxxas 2WD kits, you might try fitting a transmission case from one of those similar Traxxas kits and see if you could swap out the whole transmission. I can't see to find a good pic of the transmission case itself to see if it looks the same or not but what I can see of the chassis design a layout makes me think in this direction.
Traxxas wont work. The RE Pro2/Ofna/Team C TS2 (all 3 trucks are basically the same) use dogbones, and the Traxxas shafts wont work without swapping the rear hubs, and i really dont want to put that much money into a discontinued truck i use sporadically.
EDIT: Someone else said the AE ball diff might work, but, they are $50, and i really can't afford to buy a ton of parts that wont work. I might pull apart my Losi 22S and see if that gear diff will work.
Ahhhhh ok. Wish I could be more helpful. I dont have any experience with any of those kits. sorry
