Ok ,so we got past the glo-plug stuff!
So if that stuff is good ,then we move on to the next faze!....
So now the fuel system ,make sure that you clean out the fuel tank ,any old fuel or residue needs to be cleaned out
of the tank ,I use hot soapy water an several good hard shakes along with rinsing a few times to get the soap out ,
then I open the lid ,an cram a paper towel in an shake it around to absorb moister ,then put a little fresh fuel in there ,
give it a few shakes ,then dump it out ,it is now cleaned!
Put fuel tank back in an install the fuel lines ,one to the carb an one to the muffler ,make sure the one is attached to
the muffler!
Put fuel in tank ,hold your finger over the exhaust to plug it off ,at the same time ,try starting the engine ,the fuel
should start to flow through the fuel lines ,if it doesn't ,then you have a plugged up carb. ,but first see if you can get
the engine to draw the fuel up to the carb. on its own!
