I am still working through mounting issues. Arrma does offer 6S shock stand off.
https://www.arrma-rc.com/en/product/shock-standoff-4/ARA330703.html
These seem like a pretty good step in the right direction.
The 6s shocks are BIG! Large diameter body and giant springs compared to the "normal" 1/10 scale shock body.
The 1st set is much smaller.
The reason I had to put the 2nd set of shocks together with pieces of 1st set was due to lower A arm clearance and spring compressed was interfering with full compression. I def had to "make" them fit.
There are pretty good measurements availible for the shocks on Jenny's but you can contact them (or me) for specifics. Jenny's has been awesome about answering my questions accurately. Very helpful!
Keep in mind, The clock is ticking at Jenny's. The car is disconn'd so the 1st set I posted at Jenny's disconn'd too!
I bought another set to replace the first ones I took apart. They are in a zip baggie on my table still.
Maybe not the "ultimate" titanium nitride heat hardened... but these shocks are pretty well built. They move smoothly enough for any level of precision I will ever get out of the rest of the suspension. (like from plastic flex)
These shocks are built with bodies and shafts that could be consudered "oversized" for small scale buggies. While they might be heavy, unless you flip your car over and grind them down on the asphalt like I managed to, or HAMMER something directly on the shock itself at full tilt speed, I don't see ever breaking these things, bashing or racing.
In short, for $20.00, I recommend rolling the dice.
70mm is accurate eye to eye btw.
The first set (gray/black/orange) are plastic bodies just so I mention it.
You WILL need to change oil and springs as mentioned also.
Check the fit before you invest in the rest of the fun though!
You can ask them but Jenny's would prob let you return the shocks if you don't mess them up!
If they fit on your car, you WILL be happy.
Your stocker spring/dampers are just like the DeeR/C units. Very bouncy and not really functional even it you rebuild them.
Arrma are actually shocks! Lol!
