Kyosho .32 xxl nitro carb settings
EvilChico69
Hey guys i dont know why its a secret but i literally cannot find the settings for this engine. I looked through manualf for engine plus a car it was in and nothing. I can usually find settings for any motor and for some reason kyosho said no lol. Thought i would summon the gurus for advice. Thankyou muchly
"Factory" settings usually have both needles "flush" with the housing they go into. This will produce an all-around rich tune which you then work down from, leaning out the needles bit by bit.
Thing is the carb has a rubber thumbscrew on hsn so i can't tell where flush is. It seems to run ok but gets hot. I think i will just make everything rich and go from there. It came from australia to uk so i assumed it would be rich but i guess they only got short goes with it lol. Find it weird kyosho dont give base settings for it
Ah, that is a little trickier. If you gently screw it in until you feel it bottom out, then unscrew it 3 to 3 1/2 full turns, that's a pretty common range for standard factory settings.
I think its the lsn is the issue. If it would stop raining i could just annoy my neighbours until it runs good lol
