Any air leak would cause an engine to have high revs ,it causes the engine to lean out ,also ,anything in between like a leaky
tank or dirty tank filter ,bad fuel pressure to the tank from the muffler or even a combination of it all!
The best thing to do ,is go an seal the engine ,make sure the head bolts are tight an while it sits an cures ,go over
the fuel system ,make sure the tank is clean & its filter ,make sure the tank lid seals good ,make sure all tubing is
good an in its right place ,also make sure that the header & pipe coupler is sealed tight with zip ties!.....
