I would have, but it would have melted the plastic tranny case.
I had to drill it out and machine a new hole for the grub bolt.
I did heat the aluminum with a solder torch as much as possible, but didn't come out.
I took it to the LHS where I work as a tech, and we broke 4 Associated allen tools on this stupid grub bolt.
We gave up and put it in the drill press.
As Sunnyd's question, Yes.
team associated makes a forward only conversion.
the benefit of that, is to lighten up the drivetrain, and now the tranny has less weight to spin.
Forward only means no reverse. can't use reverse when racing, so i didn't need it.
I just bought this truck last night, and plan on racing it. Thats why I did the conversion.
the reason why they use the RED loctite now on the newer GT kits, is because they had a lot of problems with the first generation of kits losing the universal grub bolts.
Oh they fixed that problem!!
Now you can't get them out for nothing.
newer GT's try Dynamite on those allen bolts.
this is all the steel parts no longer used after conversion.
This is the part that butts up against the tranny, that we had to drill out.
