Just bought a new car
nubarjan
Which engine is good thats not too expensive.
I just bought a tt-01 chassis car.
It's got an enzo body. I did a really good job painting it.
I will post pics tommorow.
Mostly street bashing on tennis court type stuff, but something I can race,
Also something fast so I can drift
we need more info
what price range..
do you want screaming fast or durable
I'm not up on onroad cars so i dont know the "tt-01" but if its has options then what options.
are you going to race??
do you want to race later?
how good are you at tuneing
ect
Under 120
Fast yet durable
Want to race later.
Can tune moderalty
ransmission through a shaft-driven 4WD transmission. Mechanism and battery are loaded in the bathtub chassis in a flat position for greater stability. Low center of gravity and 4-wheel double wishbone suspension insure top control. The tightly sealed gearboxes feature differential gears that provide smooth cornering.
Basic Specifications
Total length: 457mm, Total width: 202mm, Total height: 110mm, Clearance: 9mm, Weight Fully-Equipped: 1,490g (Measurement includes TP-S3003 servo, CPR Unit and RC2400SP Battery with RS-540 motor) Wheelbase: 257mm Tread F/R: 159/157mm Chassis Shape: Bathtub Steering Tie Rod: 3 part Suspension: Front and Rear Double Wishbone Caster Angle-F/R: 2deg/0deg Camber Angle-F/R: 1deg/1deg Toe Angle-F/R: 0deg/0deg Damper: F/R Friction Damper Transmission Type: Longitudinally placed motor with Shaft-Driven 4WD Gear Ratio: 8.35:1 (standard in the kit) Diff. gear system: F/R 3-Bevel Diff Speed Controller Tire Width: F/R both 27mm Tire Diameter: F/R both 65mm Tread Pattern: F/R Racing Radial Type Type 540 motor included
Tamiya Hop-Up Options for TT01 series Chassis
How are the RS-540 Sport Tuned Motors
Yo, i have a tt-01 tamiya chassis too, the best kind of motor(in my oppinion) is the Speed Gems 7turn double wind Cryptonite motor
i just got it 3 days ago and it was about 40$
its a 7 turn so you knows its gonna be greased lightning and it works with the stock tamiya ESC....
i got 6 mins of run time with my old school Sanyo 1200mah batts, i havent tryed it with my 3000s yet
oh yeah for drifting i go with the tamiya stock silver can motor with pvc pipe pressed on the rims, it works great
How is the Sport Tuned Tamiya motor? Like a off the shelf RS540S with a bit more nerve.I purchased one just for kicks to see how it performs.
You better get a Trinity Monster Horsepower stock,it outperforms these "Sport Tuned" Tamiya motors with ease.
Hmm if that questions for me... "i donno"..lol....when i got the kit from Hobby town, it came with a silver can motor, i know it wasn't the Speed Tuned one tho
The stock esc can handle a 7 turn? WHAAA , Pretty sure the ESC will not handle a 7t :2cents:
A stock Tamiya ESC that handles 7 turn motors! It will fail that is a sure thing.
These cheapie ESC's are designed to handle 19 turn and up motors.Any low turn(14T and down)will tax severly the budget tamiya ESC.
Unless a tiny pinion is used and car never pushed too hard,and even then.
You want to use low turn motors get the proper ESC
lol....it works.... and its fast......i have a temp sensor or mine tho...and it shuts it down
yeah..i know about the winds and what you should use but.....i live dangerously..lmao
