Spikes
I bought a used 2.5 Maxx that I have been tweaking on daily for a while now. It's a powerful machine, a real wheelie king on both grass and tarmac. I keep it tuned a bit rich as I'm not a top performance junkie yet. The truck was only broken in then put in storage for a year before I bought it. The whole truck looked BRAND new. The engine was gummed solid when I got it. I took the engine out and freed it up with WD-40 and hand power. It's got good pinch and psycho power, but I can't find a happy idle.
Once the engine decides to calm down it will die if the idle is too low or rich.
Take off power is awesome, and I have a good stream of smoke above idle. If I richen the low needle more the idle drops and dies after a bit, if I lean it more I get a hesitation on take off.
The thing is, I know the 2.5 is finiky, but I can never get it to idle right. It absolutely screams on the high end, but either idles so high the tranny lurches every few seconds or drowns out rich and dies. (I know it's rich because I have to have the glow stick on for a bit to clear the excess fuel upon restart and it smokes).
When I stop it (hit something) it idles very high for a random 3 to 15 seconds and then drops down to a lower idle quickly when it's ready. It 'feels' like it's got an air leak and is leaning out, but why would it run so perfectly on the high end, and idle GREAT once it decides to? It usually starts up with a high idle and doesn't calm down much until it's warmed up. The strange part is there are two distinctly different idles. The high one, with the truck lurching every few seconds every time I stop driving and the low one a few seconds later when all is well. The transition takes only a second.
I never thought much of it until I bought a Savage with the Picco .26 and it's the most mild mannered engine I could ever ask for. Set it once for the weather that day and it's good for several tanks of fuel (I run it a bit rich too, but it wheelies like CRAZY!!!).
I know the standard advice will be change O-Rings and seal the engine, but for the engine to go from high idle to great idle manners and run super on the high end. How could an air leak cause that?
Thanks!
***EDIT*** I should add, sometimes the high idle will not drop down. Sometimes I could let it idle high for 3 minutes and it won't come down, but if I blip the throttle it might stay high, then come down - and it might not.
Also, it isn't a servo setting issue. I always check the servo and make sure the slide has returned all the way to idle (it has about a 1mm gap).
Thanks!
