Finished!
Ok guys,let's say we finish this up and get it off to it's new home?
We left off last time after using the readout on the mill to obtain the distance between the mount and axle holes. Now it's time to complete the business end of the swingarm.
Once again I start with a radius on the end and blending the corners to match the rest of the arm.
Next I mill a pocket in the arm for a carrier slide to allow for position adjustment.
Then a slot for the axle.
Now I have to change the position of the arm so I can drill a clearance hole and counterbore in the end. This will be for the adjustment screw,the couterbore will keep it from protruding out the end and makes for a clean/neat appearance when assembled.
After repeating these steps for the other half of the arm,it's time to make the carrier slides. I debated on using a different material but decided for now just to stick with aluminum. So first I take a piece of the scrap I sawed off from profiling the arm and clamp it in the vice.
Face off the top so it nice and smooth and mill the profile.
Then I drill the holes for the axles,tap a couple of extra holes for some locing screws and clear away the extra material around the slides.
Now I can saw off the 2 slides and mill them to the desired thickness.
Then I stand them up to drill and tap the ends for the adjustment screws.
The carrier slides are now complete.
The last step is to make the adjustment screws. I start with some 3mm set screws. With a small(tiny) grooving tool I put in 2 slots just big enough for a couple of "e" clips. The clips will retain the the set screw in place,one in the counterbore of the arm and the other in the pocket for the slide. This traps the screw so that when you turn them,the slides move.
A final adjustment to the length of the screws and some assembly and TA DAAA!!!!!!! The arm is done. Joe,it's on it's way!
