Not trying to pooh pooh your choices, but pointing out some issues that may come up.
The price is a red flag. The cost of the HobbyWing parts alone is probably at least $10-$15. How can these guys design it, test it package it, pay for ebay and ship it to you for $20? Steal the design, use cheaper parts and don't support it.
Most legit companies have a rigorous test plan, documentation and safety specifications. I doubt they have any of this. They probably pulled a design stolen from someplace and paid for the assembly with cheaper parts.
Generic Chinese product specs are generally a flat out lie. The 120A is probably peak, best case, downhill in a tornado. It's could be made up or pulled from a max current spec on a FET, who knows. As an assembled product, when it says current, they should tell you under what conditions conditions, peak, average or continuous whatever. So I'm calling BS on it.
The HobbyWing referenced above give you continuous and peak ratings. Notice the peak is about 6x the continuous, which is about right.
They even lie in the listing. It says the it is 16x6x5
cm, but the picture shows something completely different. Also notice is say cm in the specs. 16 cm is like 6"!???
The spec don't say what the battery requirements (2S-3S, 4S??), motor limitations (turns/KV). This stuff is kind of important. Maybe it's in the fantastic documentation they send with the product, but I'm thinking not, since they can't make a proper eBay listing. Also can you program it, what's included, instructions, warranty, support, etc? They basically say it's an ESC.
I'm not 100% sure but this look similar to the one you have shown.
https://www.rcgroups.com/forums/showthread.php?2466764-TSKY-120A-from-GearBest-Review
I think you will be disappointed. I would spend a bit more money and get something that has been tested in the real world.
I just found your build and noticed it has a brushed motor?
https://www.rctalk.com/forum/threads/chapman-tamiya-neo-scorcher-build.139056/#post-1391533
Are you planning to upgrade to brushless or stick with brushed?
Most brushless ESC allow you to run a brushed motor (
check the documentation), but you might be paying extra for features that won't do anything for you. However, if you're planning to upgrade later it's a good plan. There are some good deals in the classifieds and ESC/motor combos too.
