In the motorcycle world you can add a stroker crank without changing the porting (even on a 2 stroke). The way this works is by using a spacer at the base of the cylinder to keep the ports lined up in their original position. Strokers usually gain you more TQ than HP. Stroking an engine does not add any displacement, a big bore (boring the cylinder for a bigger piston / sleeve) does. Stroker kits are usually the last stage in the quest for HP on a bike because the cost is much more involved than say a good pipe or big bore kit. Plus, they put more strain on the crank, con rod, con rod bearings, etc. The same basic physics principles and short comings would apply on a 2 stroke RC engine.
