I would like to throw the Dynamite Mach 2 .21 SG out there. Very good engine for the price. Can be had for under $100 new occasionally, typically $130. My suggestion since its your first nitro engine. When the Mach 2 goes, upgrade. You won't be disappointed with the Mach 2 and if you happen to destroy it really fast it won't be as painful as say destroying a top tier Nova or O.S. Etc... You can actually look at the specs for each engine your interested in. For example the Mach 2 produces 2.4hp at 33,000 rmp's. The O.S. 2.63 at 34,000. LRP 2.93hp but doesn't give the rpm's to achieve that power output. Nova doesn't tell you max HP, at least not that I could find, but it produces its max power output at 37,200 rpm's. Werks B2 exact same HP and rpm specs as the Mach 2. Those are the top engines from O.S. , LRP and Novarossi. Aside from the power differences the quality of the parts are definitely going to be better in the higher end engines but they're also running at just about the limit for these mills.
