Sounds like your LSN is too lean and your HSN is too rich. You should never adjust the HSN to set the idle, if you lean it to the point that it has any effect on the idle your mid and high end will be dangerously lean.
Yeah, I have trouble articulating my thoughts. I guess to add on to what I said before. There have been times where my pede would idle just fine, but any sign of throttle it would bog and not move. And when I was new I probably went to the LSN instead of the HSN. And I guess that's what I was really trying to say instead of the hsn and idle thing.
I'm not trying to give bad advice, I apologize if I confused anyone.
Make sure your idle gap is set correctly. I use a small paperclip and then make it just a hair smaller. Works well for me.
I know for a long time I chased a tune around and couldn't get it 100% but enough to run good and not over heat. But after putting at least 2.5 gals on my trx .15 pro, I set everything back to factory and re-did the tune and it was pretty easy to get going really well.
What I'm trying to say is, if the engine is still new, with maybe 1 gal of fuel on it. It may just have to be truly broken in a little more before you can get that perfect tune. Just try to get it working good, decent idle, good power, smoke and temps put another gal or 2 on it then you can really do a performance tune.
Speaking of, how much fuel have you ran through the engine?
