Well, if the rest of the truck matches the body, that looks like a FS racing 1/5 scale truck that originally cost somewhere around $700. I just traded off a FS racing 4wd truck with a 30.5 engine and here are my thoughts. I had a lot of fun with it but I also spent $$$ maintaining it. The drive train is very bad design. The rear diff has a set of very fragile gears that cost around $75 if you can find them, and you are going to bust them sooner or later. The entire drive system consists of a bunch of cheap bearings mounted into bad fitting bearing housings and you have to shim to get all the gears to fit the way they should. And regardless of doing all that, it is still going to sell-destruct. Everything on this truck is a bad design. No one here in the USA sells parts. (and probably not in Canada either!) You have to order from Aliexpress. They are located somewhere in China I think. And all the parts are kind of expensive.
So are you now starting to understand how I really feel about it? If you buy this thing, you will not be able to just run it and just have fun. You will spend lots of money to get it there and keep it going.
