I told my wife it's sweetdiesel fault
Revo Rancher said:
Great idea, Plaid, I'll llok into that for myself. So, by what you are saying, you have a 5 gallon tank(no compressor attached)that you fill with air and then put that under your bench and tap into the block?
Yeah..I have a block but it mounts on the tank and I need to reseal it...then I'll move it up to the bench and I can have up to 4 pneumatic outlets....I found a 12VDC compressor at my dads shop a while ago that I'll just hook to it instead of running a hose into the house when I want to fill it....unless it's just noisy as hell.....I have the regulator / trap you had in your link already but I am liking that one Rob posted from HF...it has a tab I could just screw it into the back wall of the bench and run all the stuff off that.....I'm trying to get into using the airbrushes more to paint but I have some cheapo ones I'm not sure have adjustable tips......I have to tilt it to get a wide spray, If I turn the tip it doesn't do any adjustment it seems......thanks for the links too....I found the clear stuff but wasn't sure since it said "for badger airbrushes"...but the 20' braided line from tower is what I'm looking for.......what do you guys use for holding the paint while painting...the lil side bucket or the closed jars w/ the stem?....I'm embarrased to post my attempts w/ this thing......I'm getting ready to try a new body so wish me luck.......
Plaid, I've been using the little side bucket on mine. Just used it a couple of times so far, but it just seems more convenient. Being less to clean when changing colors.
Good luck with the body.
Has anyone mentioned the disposable filters?
Anybody using them?
The SS cups off the top or side are best. Like it is said, less weight and obstruction.
