How exactly are you “priming” the carb? Just using whatever starting device (pullstart, roto/EZ-start, starter box, etc), and expecting to see fuel move from the tank to the carb?
If that is the case, then you are waiting for it to rain lol… Your tank requires PRESSURE to push fuel through the line.. When it’s already ran, and primed, it’ll fire off normally. If it’s been sitting, you will need to do one of three things to achieve this:
1) plug your exhaust stinger with your thumb, and spin the motor over until you can see fuel flow up the line to your carb.
2) pinch your pressure line, and open the lid by using your tank pull, and allow to “slam” shut. Do this 5-6 times, and also watch the fuel flow up to the carb.
3) remove your pressure line from your exhaust nipple, and blow into the line until-again; you see the fuel flow up the line into the carb.
Hook up your igniter, and fire off as usual. Have fun.
