TWOCANE
I went from 30% to 20% and had to retune like crazy but she is running with no problems. I've pnly ran 1 and a half tanks of 20%,. Is it ok to change since she is running fine or should I go back to 30%?? Thanks
the increase in nitro, which causes the engine to run cooler because of the higher nitro content.
Don't want to start a big debate but, More nitro will not be cooler if you are using the same standards of tuning.
You probably hit 'back' instead of 'submit'. I've done that twice today.where did my reply go?
Have you ever noticed how cold your hand gets if you spill nitro on it? That's due to rapid evaporation. Inside the engine, where it's mixing with air it has the same effect. The higher the nitro content, the faster the evaporation, so it tends to cool the engine more.
No need to debate, more nitro runs cooler, think about it and get back to me.
hint,if you go from 20 to 30 you will need to lean it out.
