Thank for the reply buddy, really appreciate it.
You are right re new buggy I am going to up grade mine a bit .
How do you find your breaking, my breaks are not very good, just cannot get them to break properly. I am thinking of up-grading to quad breaks from the Pro version. Do you think it will fit??
What about engine, what would you get??? Something descent that will not cost a bomb, say up to USD.200
I'm using the stock brakes, and they work perfectly fine for me. But I'm running a relatively high-torque servo which puts out 85 oz-in. @ 6V. It's the stock steering servo off a traxxas t-maxx. Nice and cheap and gets the job done. What I'm trying to say is, if your servo doesn't have at least 80 oz-in. of torque, upgrade the steering servo. That'll give you much better braking...
For instance, in my savage, I've been running the stock, single disc brake for about 3 years and still have perfect braking because I've got my linkage set-up nice, and I've got a Hitec 625MG servo for throttle/brake.
So, be sure to check your:
-Linkages
-brake pads
-servo
I think the servo that comes in the TQ, (assuming you got the one with the electronics) is a cheapo little standard servo which puts out somewhere around 48 oz-in...
As for engine, it depends on your track. Depends if it's big and long, or small and short. Generally, for a tighter track where you don't have many straights or anything, you're going to want an engine with less ports.
Also, check around and see what others are running, what the recommend, and why.
I will likely buy a HotMod Collari B3 since I love the sound of a modded engine (lol), and my track is very tight and technical where no one ever gets up to top speed. The engine retails for around $240.
