REVO-5309
Hey I have an lrp z28r s3 motor. The HSN is loose and keeps winding down and leaning the motor out. I'm at work ATM, wondering if there is something I can use or do to fix the rubber or do I need to buy a new seal?
New o-rings are a good idea, but I would not recommend teflon tape because it will get into places where it doesn't belong. Use a dab of green slime or dielectric grease on the o-rings.
I'm going to share a trick that I use, call me crazy if you like, or else don't blame me for your potential mistake when trying this idea:
Take some pliers with semi-fine teeth on them (like needle nose for example) and squeeze the threads on the hsn needle hard enough to leave teeth marks across the tops of the threads. Make sure you do this little by little if once isn't enough. Thread the needle back into it's home and it should not move again.
---------- Post added at 5:07 PM ---------- Previous post was at 5:07 PM ----------
Fyi, Nitrohouse may have the parts.
