Is this a new or used buggy, or more specifically, is the engine new or used? Be sure the carb is working 100%. With the engine not running, use the radio to move the carb thru it's whole stroke, forwards and brake. Look for and possible places where it could be binding up. Nothing hanging up when you remove the throttle rods from the servo arm as well? Make sure the hardware on the carb is tight.
Have you since checked the servo and radio setting to be sure it's not an issue with one or the other? Is the radio new or used? I would start here at the very beginning, insuring that you have a 100% charged batteries (or new batteries if you are using alkalines) are you using a battery pack or AA batteries in the receiver (in the truck)? The batteries in the truck are a VERY common weak point. It is recommended that you simply replace them with a pack before you continue. The AA sytem Is a plague! Is there a servo saver installed here? Servo savers are great in some applications, in this case, it would be the route of all your problems. If there is one installed here, I recommend you remove it and retest the system making sure to be thorough BEFORE you take it back out for a ride. Check all of the radio systems wiring to be sure you have no stripped, bare, cut or shorted wires. Be sure that your plugs are also in good shape. Take a moment to pull the arm off of the servo to be sure you don't have a stripped arm or that the servo itself is not stripped there, You should also check to be sure that the servo isn't stripped internally. Because the gears inside a servo are usually very fine, it can be tricky to find the stripped part(s). Since you've got most of it apart already, it's easy enough to just pull the servo out and be sure by pulling the top cover. Be sure to inspect VERY closely!!!
At this point, I ask that you repost with what you have found here. I have given you a TON of things to look at. Before digging much further, tell us what you find and we'll respond with more recommendations.
Good luck!
Look forward to hearing what you've come up with so far!!!
