There are several ways to adjust the travel of the brake. First, make sure the pads are not worn down too far. Next, you can change the length of the arm where it connects in the trans. The shorter it is going to the servo linkage, the less travel is needed.
It's the green linkage coming straight up from the bottom of the trans...
Also, check these pads for excessive wear:
Rolex,
Is that excess wear on your brake pads from waxing?
