I had it started inside got it warmed up a little bit took it outside. I ran two tanks through it got max temp of 130. About 100 short. I just sat it up on a box and let the wheels spin. I was going to run a few more tanks through it like that then just baby it around in a circle for 3 or 4 tanks then start giving it more gas. Idk if it'll work or not but going to try that. Dont really want to have to wait.
I don't like electric rcs I wouldnt even consider buying one but thanks for the idea.
Ok so in the summer when I was breaking in my truck. I had it up on the stand to do the heat cycle and well I was doing this it started revving up real high. The wheels weren't ballooning are anything like that it did for about 15 secs before I stopped it. What kind of damage can this cause. It just did this well I was letting it idle too I never hit the throttle. This was the first tank, it also did this on the 4 but that was me trying to tune. It's my first nitro. Also one tank I got a little over zealous and didn't wait to cool down before refilling and starting again. I was just having to much fun, what kind of damage would that cause. I've only done 4 tanks, I work alot and was having problems with my truck mainly breaking a few pull starts and a servo dying. I live in the sticks and waiting for parts is a pain also finding repair time is also a pain. It's been put away for the winter now, kind of sucks but I went out and got a traxxas bandit for the winter. I like its no nitro though.
Thanks again for all the advice...I thought about every comment but in the end it was worth the risk for me have $600 into it for a xmas gift to myself didn't wana wait till april to run it. If I have to spend another $200 for a motor and wait till april pockets are deep enough to buy a new motor.
The fumes are poisonous, try to avoid breathing them all together! I would only idle the engine for a few minutes and then start driving it fluctuating the rpm, it is hard on the engine to sit at one rpm for any length of time, just like a 1:1. I don't recommend running it "very rich", just slightly rich is fine, the LSN has to be set almost perfectly tuned or the engine would not idle so you can follow the same idea with the HSN as well. Running very rich will only put more stress on the internal parts because the fuel/oil will build up in the combustion chamber and we all know that you can't compress a liquid so the compression will be higher with the additional fluid. Heat cycling is debatable "IMO" as I believe it takes a substantially higher heat to temper the materials, much higher then what you can achieve doing a break-in, or even fully tuned for that matter. Stay out of the snow! that is the biggest killer imo because when it hits the cooling head it will suck the heat out leaving the engine cold. If the engine is run cold for extended periods, once it gets warm out and the engine can get to normal running temps, you will find that it will act like a worn out engine as the tolerances were set to run at a much cooler temp, if that makes any sense. Enjoy.![]()
Metalhead Matt; said:My rc's are my buds.![]()
