richierich
Gone - bye bye.
ok i got this idea and tryed it on my hpi flux and it works great.first get a prouduct called plasti dip at home depoet its $7. take your servo and receaver and just dunk it in the can pull it out wait a half hour and redunk let it sit overnight to dry.you will have a very tight rubberized seal.then just take a razor blade to the eletrical inputs and aroud your servo horn and your done.as far as the esc remove the esc take the plastic cover off to expose the circut board put the plasti dip all over the circut board and let dry over night.DO NOT GET PLASTI DIP ON THE HEAT SINK the heat sink needs to get cool.as far as the motor you dont need to waterproof this i put my motor in 3 gallons of water for 5 min and it works.their is a video on you tube on how to do this good luck this works
Anyone reading this, please, DO NOT follow his advise, do NOT coat the pc board with plasti dip.
You are NOT supposed to cover the pc board with plastidip. You can use it on the case, but NOT on the board. To waterproof the board all you need to do is give it a good heavy coating of dielectric grease, then close the case back up.
