How long should a 4S 5000mAh LiPo take to balance charge?
King Mustard
United Kingdom
I am charging my first battery.
I have a SkyRC S65 charger and entered the correct details in.
So far, it has been running for 65 minutes.
Does that sound about right?
EDIT: Funnily enough, the charger sounded a chime around the 68-minute mark to say it had finished. Now that it has finished, I presume it would technically be safe to leave like this? (for example, if I go downstairs for an hour or so)
Yeah, it is safe to leave it fully charged.
When I am done with a LiPo for the day, I storage charge them. Mine typically never sit more than a few hours fully charged. But I have forgot about them a few times and they went a day or two before I discharged them.
Interesting.
I fully charged today (Tuesday) it in preparation for using the car on the weekend (in case I forgot to charge the battery on Saturday or Sunday and had to wait an hour and a half for it to charge on the day).
Are you saying I should not leave it fully charged for 5-7 days without using it? If so, are they really that dangerous?
Interesting.
You will degrade the battery life by leaving it fully charged. I would recommend you set an alarm to finish charging them about an hour before you go.
If you didn't already know that, I highly suggest you read through this...
https://www.helidirect.com/blogs/ne...HB74PJulBVdhmV3IcNVr_qYnc9oRaUvsaAskjEALw_wcB
To answer your original question of how long it should take to charge, it depends on what amperage your charger is set to and the current voltage of your battery.
Typically 1C is the safe charge rate for most lipo batteries. So basically for every 1000mah of your battery you can charge at 1A. So your 4000mah battery is safe to charge at 4A.
At 1c a completely empty battery will take roughly an hour to charge fully. So if your battery is completely drained and hit LVCO you’re be looking at about 1 hour to charge. Seems like you’re on the money.
That being said, depending on my batteries I’ll sometimes charge them up to 5C. It’s not the best for them but when I’m ready to run I’m ready to run lol
I should add that a proper balance charge can add to the charging time as the charger slows down in an attempt to balance the cells but I’m not exactly sure on how the charger performs this. I just know that the closer it gets to full, the slower it will charge when set to ‘balance’
As I fully charged them but did not intent to use them for 5-7 days, using the S65, do I need to Discharge them then pop them into Storage mode, or just pop them into Storage mode?
You can pop them on the storage charger, but it will take a while for them to reach storage capacity from full charge using that charger.
May I ask, why will it take a while? It sounds like it is removing the charge to make it safe to Store, but I presume it is not, as that would surely just be the same as the Discharge function?
Don’t use discharge, that will kill it for disposal
You will need to storage it with the charger which will take a while, likely quite a bit longer than it took to charge lol. Not sure of the charger specs….fastest way to discharge the battery to storage is to go run the vehicle
It is soaking outside and the car (Maverick Quantum RX Flux) at stock does not feel very waterproof.
I posted this in another thread
The way I understand it, when you start a charge cycle, your LiPo charger is just dumping energy into the battery through the larger "discharge" leads. The ones with the EC5, or XT connector, or whatever. You hear of racers charging at 30 or 40 amps. The balance leads would not take that constantly. So the discharge leads are also handling the charging.
Once one single cell reaches 4.2v (or 4.35v for high volt LiPo's), the charger stops charging at the higher amperage you have selected and goes into balance mode.
During the balance cycle, the max amperage your charger can charge at will only be what the charger's balance circuitry can handle. The Hota D6 Pro for example has 1.6A balance current capability. What this is basically, is how much amperage the internal resistors can pull. Most budget chargers have a 1A balance circuit. Your SkyRC S65 has a .35A balance circuit. So once in balance mode, your charger will become painfully slow.
Once in balance mode, the charger is still charging each cell through the discharge leads, but it is drawing the extra voltage out of the full cell(s) through the balance leads and burning that energy up through internal resistors.
That is why the balance circuitry capability is so limited. It can only discharge at the amperage the internal resistors can handle. So you might start at 5A, but your battery will finish charging at 1.6A. If it didn't do that it would burn itself up trying to get rid of all that energy that fast.
As for the discharge function, that is used if you want to discharge the battery down to a specific voltage. Handy for sending batteries to their doom. As said, use the storage mode to put your cells at 3.85v or so per cell.
It will take a long time to drain them from 4.2v/cell to 3.85v/cell because the charger basically has to use resistors to drain that voltage off. It will just turn it into heat. You'd have more fun taking an RC out for a rip to drain your batteries.
i just slam charge everything at 10-15 amps these days. lowers IR anyways.
