Renegade88
Yesterday afterwork: Itwas 16c out side with a nice cold breeze.
Main needle set at 3.5 turns out LSN set at 2.5 out.
Started engine after 3 pulls after priming with ARO first.
Ran first tank with vehicle runing around the nearly mid rpm range then slowly bringing it up ti middle rpm range, feul spewing out the exhaust when I take a turn. Engine temp was at 90c.
Allowd engine to cool with pistonat bottom of stroke.
Leaned main needle out 1/12th of a turn and ran 2nd tank the same and 3rd.
4th Tanks leand HSN aother 1/12th of a turn and ran motor in low rpm to mid rpm feul still spewing out. engine temp was at 90c
Allowed engine to cool with piston at the bottom. Afterwards I sprayed allot of ARO in.
I am going to run another 4 tanks of fuel today with leaner setting going a bit up to short high speed bursts.
How amI doing so far?
