How do I take the hex brake hub off of HPI Savage
Hairy W Bush
RCTalk Racer
Florida East Coast
I've already removed the dogbone and side screw and the thing won't budge. The piece in the center doesn't appear to be a screw. Assembly diagram doesn't even show anything about whatever that is. I'm afraid to try and pry on it any more.
i think it's steel...I can't find my magnet. so this is just supposed to pry off?
No, it's supposed to just slide off. There isn't a set screw anywhere on it? Pics would help here to make sure.
I removed the one on the side already. the piece in the center doesn't appear to have any drive shape and my wrenches won't do anything
Oh, no those aren't wheel hexes. Those are drive cups. Those are held in by a pin inside the diff housing.
Or wait. I see a set screw hole. Some RC's have cups that lock onto the drive with a set screw. Did you remove a set screw?
Was it just the set screw or the entire set screw pin? HPI uses a set screw/pin thing and sometimes the pin breaks off, so when you "remove" it, the piece you take out looks like a set screw. That means the pin is still stuck in there (or it fell out the hole when running).
Part 86094 is the screw/pin thing:
Once that pin is out in it's entirety, the hub should pull off the shaft (86081 is the shaft shown above). It may be seized to the shaft, both are steel and could have rusted. So grabbing the front hub (86082) with pliars, then rocking/twisting the rear hub (86322) should break it free.
