krimy123
RCTalk Racer
- Thread starter
- #21
I was wondering let’s say I get done playing with it and there is still some power in the battery ? Do I leave it as is or should I remove the power with the charger?
Any infrared gun off amazon should work just fine. Mine cost $16 I think, and when I checked it against a few things it seems pretty spot on.Yeah I did get the Hotwire for my Tekin , so on that front I should be able to set it correctly.
I'm also looking into a decent temp gun.
Even with 5~10 watts of discharging power, the resistors inside of most chargers out there create lots of heat. The compact chargers of today have no room to accommodate larger/more capacitors for more discharging power, and the heat that would be created. One other great thing about your charger (Hota H6 Pro pictured)... external discharging capability. If you have no time to run batteries down in an RC racing/bashing session, then perhaps building a discharger of some sort may be right up your alley to help bring down voltage of cells for storage.I was wondering let’s say I get done playing with it and there is still some power in the battery ? Do I leave it as is or should I remove the power with the charger?
I thought about buying an Optima deep cycle battery to discharge my packs back into.Even with 5~10 watts of discharging power, the resistors inside of most chargers out there create lots of heat. The compact chargers of today have no room to accommodate larger/more capacitors for more discharging power, and the heat that would be created. One other great thing about your charger (Hota H6 Pro pictured)... external discharging capability. If you have no time to run batteries down in an RC racing/bashing session, then perhaps building a discharger of some sort may be right up your alley to help bring down voltage of cells for storage.
View attachment 155469View attachment 155468
