hobbywing 8bl150
Huyyy
hello! i have a little bit stupid question because I'm scare to burn out another esc
Can i run my Hobbywing 8bl150 with the 4268 2150kv motor with max voltage is 21v and max amps is 116A
and can i run it in 3s,4s,5s,6s lipo or it just run in 3s,4s,6s lipo
Well a fully charged 6s is 25.2V so I think the motor is only good for 5s. It might survive or it might not. The ESC should be fine though.
the esc said 3s-6s so can i run it in 5s connect batteries 2s and 3s in series
Yes as long as the cells in the lipos are the same (same brand & capacity).
Some escs don't detect 5s lipos for the LVC properly so if it doesn't beep 5 times when you turn it on you might have to program it to 5s lipo.
Yes
Theres one important thing..we use different Lithium batteries some are Lihv-4.35 volts a cell lipo- 4.2 volts a cell and others 3.65 volts a cell(not used by many).just make sure you dont exceed that 21 volt mark
If you're going to run 2 batteries in series then they need to be identical batteries and they should be a matched set. I would not run two mis-matched batteries in series.
