I've looked all over the web and can't find a simple explanation on this, so I am hoping someone can help:
What is the relationship between Hi/Lo rates, and Safe/intermediate/Advanced modes on Spektrum receivers?
Spektrum says that "In the upper, or “HI” position, servo travel is 100% on these channels. In the lower, or “LO,” position, servo travel decreases to 70%."
I am not clear on what they mean by "servo travel," and how this relates to the three flight modes. Is that how much of available travel you have for the flight controls? For example, on Lo rates, does that mean that the rudder, aileron, and elevator will only move 70% of its potential range of motion? And if so, how will toggling between the three flight modes be affected?
For example, let's say I am in Expert mode, Hi rates: So I have full travel of the flight controls (elevator, rudder, ailerons). So I can do rolls, flips, etc. If I move the rate switch from High to Low, does that mean I am now unable to do rolls and flips because I am limiting the amount of control surface travel? And does that mean that I am basically mimicking Intermediate mode/hi rates now?
And for simplicity's sake, since I am a new flyer, should I simply stay on High rates?
Hopefully this example helps illustrate what I am confused about: basically how rates relate to the three flight modes (SAFE, intermediate, advanced. That is, what is the relationship between the two.
Hoping someone can clarify. Thanks
