Help with Hitec Lynx 3d
TwiZtiD25
I am trying to find a manual for this radio. I went to Hitec.com but some of the pages wouldnt work. I can't seem to get it to go into the programming mode. I need to tweak the trigger cause when I hit the throttle it pulls the brake (vise versa). And also it makes the throttle/brake servo pulsate. :stupid: This is my first decent radio, so any help is appreciated:radio:
Sweet!!!! I give you a PM with my address. Any suggestions on switching the throttle/brake?
I know when you get to the REV CHNL option or however it is listed (I forget which one its called) you just press the +/- at the same time and it will change the setting. Pretty sure anyhow.
Ill dig it up and send it to you. Its been a while....
Could be listed as CHNL REV or SRVO REV too.... dang I forget
u r correct christian - i also have the lynx 3d radio - to switch the servo reversing, u press the + and - buttons at the same time, then use the buttons on the right side to scroll down until u readh the screen srvo rvs. then u can use the lower +/- bttns to change it. As for the pulsing action - that is due to the ABS brakes being activated. You can turn that feature off by scrolling to the ABS menu and pressing the lower buttons at the same time, when the screen shows just the folowing "ABS ON" hope that helps. i also have my manual - if u need me to copy it for you, just email or pm me.
Thanks guys, Chris got me into the main options, and from there with a little bit of tweaking, I think I'm good to go. I am waiting on my THS pipe so I can test all these new toys out:banana:
This reminds me of before I had my ntc3...I had my novarossi in my ob4 and was bashing in the winter time with this kid who had a hpi nitro rally.
He never knew about servo reversing and his steering was reversed. i showed him how to switch it but he's like, "well i'm used to it so I won't change it to the way it should be."
Kinda funny to drive like that..can't imagine me doing that though
I hope at least his throttle and brake was right. That would be to funny if it wasn't.
