Howzit guys
Can anyone help in identifying this nitro?
The seller says its a Traxxas, but I'm not so sure.....
Cool shot man. You are bang on the money! Thx!
Thanks for all your info!
The seller wants $62 for it! Me thinks this is too much. The car is pretty old and looks kinda beat up. Missing the air filter ect ect.
What do you guys think is a good amount for a buggy in this condition? Servo's could be shot and who knows what condition that engine is in.
No, it's definitely not Traxxas.Howzit guys
I would say 50 for not running and 70 if it can runThanks for all your info!
Thanks for the response but that doesn’t help me. I was driving it till I bent an axle but can’t find a replacement I tried the 5451R axles and they are to long.ooooh weee! Now that's a Maxx!
You have a highly modified one, extended chassis, for big block, with longer center axles, and more.
i could make you custom universal axles in whatever length as long as it is not larger than 8mm in diameterThanks for the response but that doesn’t help me. I was driving it till I bent an axle but can’t find a replacement I tried the 5451R axles and they are to long.
The transmission end measures 5.65 and tire side is 3.95i could make you custom universal axles in whatever length as long as it is not larger than 8mm in diameter
i think those might be Hot Bodies, i have one i can measure
welp, stuck a driver thru my hand, called it a night, check for you in the morningThe transmission end measures 5.65 and tire side is 3.95
The front and back are the same length
Hi all,Thanks for all your info!
Might want to start your own thread if you haven't. If you do, link to it from here. Wouldn't mind seeing more photos of your maxx that show the entire top/bottom of the chassis. It may be a .15 pro maxx, which was the first version. It had shorter arms which used narrower cvd's/axles than the 2.5 and now 3.3 maxx.I also need help identifying what generation t max.. The axles I have measure 6 3/4 inch wich is 171mm center of dog bone to center I have 4 7/8 I can’t find a set that will fit in. Also the car was given to me it doesn’t have reverse. When I got it it had the motor in the pic in it
