RichardLongley
Hi Guys,
I Purchased and built an HPI MT2 18SS+
The build seemed to go well. I am a novice, and I was a little concrerned about the fly wheel setting, but I am fairly sure it is ok.
Problem is I can not get it to start. It doesn't even splutter.
I have made the following observations:
Fuel:
The fuel tank does not have a priming button, so I fed the fuel up to the carb. by blowing in the pressure return line.
I tried this a few times, and I did notice that the pressure builds if I blow too much fuel in. I pressume that this is the engine being flooded.
If I suspected the engine to be flooded at any time I removed the plug and drained it.
The Carb was set at the 1mm recommended level, and then opened further by manually adjusting the servo.
I tried it at 1/4 and at 1/2 open. No sign of life.
The pull seemed really quite stiff, so after a while, I decided that was not correct, and I loosened the plug a little, this indeed made the pull smoother and easier. But still doesn't start.
I checked the plug itself, removed it from the engine, and checked it glows - it does, very brightly.
So I am stuck,,,, I dont have a clue why it is not starting......
Can anyone give any tips??
Fuel:
