after reading through a couple learning sections of balancing heli blades, they say you can put each blade on a knife blade and mark the center of each blade where it was balanced and add tape till both blades were balanced, then it said assemble them on the piece they go on and balance that so that it is centered, well once you have it assembled and you add tape to another blade to balance the whole assembly it's gonna off balance that single blade if you were to pull them apart again.. so why can't you just balance the whole assembly and not do the blades individually?
